Extruder problem
gsorbara
(@gsorbara)
Extruder problem
Here some picture of the problem that happend two time the first time I have to take out the extruder and replace the white pipe clean everithing and reset the printer starting again, I using original PLA form Prusa.
I also already print with success some items but after the trouble I couldn't do anything more. Also the calibration looks bad but making some test looks fine but at the end in the middle of the print the printer didn't finish the job and looks blocked, the filament don't pull out.
Now everithing is in the printer waiting for your help, i have only one spare white pipe so I don't want to waste it.
thank you in advance Gabriele
Respondido : 23/07/2019 7:42 am
RE: Extruder problem
Is the printer inside an enclosure?
What is the maximum ambient temperature shown on the LCD when printing?
What is the material you are printing?
Did you slice that part or is the gcode printed directly off the Prusa SD card?
If you sliced it:
   - What profiles are you using?
   - What does the printed SD card version look like?
Respondido : 24/07/2019 8:47 am
ps: from this display --
Respondido : 24/07/2019 3:02 pm
