Everything started warping
mlubben
(@mlubben)
Hi, I recently started experiencing heavy warping issues and I cannot get them resolved :/
I attached a model where it warps very heavily. I already printed about 10 of these and I cannot get it to stop doing this.
the model is too big, so a picture has to do the job :/
I use the standard prusaslicer printer settings, tried different temperatures, slowed the print down, even tried to print in petg and nothing seemed to fix the problem.
specifically the part on the bed will lift upwards and even the part, that's sitting on the supports lifts up...
Best Answer by David:
Hi! Check if the print-fan works correctly.
Dieses Thema wurde geändert Vor 5 years 2 mal von mlubben
Veröffentlicht : 02/06/2021 10:03 am
Dan Rogers
(@dan-rogers)
RE: Everything started warping
That shape will be difficult to print because it was not designed to be 3D printed in that orientation.  You may want to add a wide brim.  The long strands are going to cause warping as they cool.  If the warping is breaking the support interface, then you'll need to try a different orientation or take steps to break up the long filament runs.   If it were me, I would try standing it on end, adding a wide brim.  That simple change in orientation will relieve the warping issues considerably.
Veröffentlicht : 02/06/2021 11:47 am
David
(@david-2)
Mitglied
Veröffentlicht : 02/06/2021 12:44 pm
