Eliminating a lot of supports
RDL
 RDL
(@rdl)
I want to print a microscope adapter for my iPhone mini.  It will essentially look like a protector case with a tube attached (to fit over the eyepiece).  Since the 27mm ID tube will be 20mm long there would be a lot of wasted support material.  I would like to print the tube, pause the print, then drop in a solid piece around it to support what will be the base or rest of the case.  If I use aluminum it can be preheated to get better adherence.  Hints & advice?  Printing filament will be flexible.
Dieses Thema wurde geändert Vor 4 years von RDL
Veröffentlicht : 29/12/2021 11:42 pm
