Elephant foot? Nozzle cleaning?
Eule
 Eule
(@eule)
I just printed a part of a box and have two issues:
1) I printed it in white PETG. Unfortunatley I printed something red before and thus I got a light pink first layer. Probably I need to run a longer "first cleaning line". But is there somewhere a setting in the slicer?
2) The lower part of the box is a bit wider. Looks like an elephant foot. But it is not directly at the first layer, because there is a fillet. So I am unsure if this is may be a different effect? What do you recommend to avoid it? The elephant compensation in the slicer is already set to 0.2.
Respondido : 11/12/2024 6:53 pm
Robin
(@robin)
RE: Elephant foot? Nozzle cleaning?
1) the purge line is part of the initial g-code, you can modify it in slicer: Start g-code in printer settings. This is the longer line used for MMU:
; purge line
G1 X55.0 F2000.0
G1 Z0.3 F1000.0
G92 E0.0
G1 X240.0 E25.0 F2200.0
G1 Y-2.0 F1000.0
G1 X55.0 E25 F1400.0
G1 Z0.20 F1000.0
G1 X5.0 E4.0 F1000.0
2) probably "bulge line" due to change of infill - difficult to say without the project file.
Respondido : 13/12/2024 3:23 pm
Eule
 Eule
(@eule)
Yes, bulge line due to a change of the infill could be a good reason. This part is a box and at the position where it happens the bottom ends and the walls start, see also the attached file showing a section view.
How to solve this?
Respondido : 13/12/2024 4:50 pm
Robin
(@robin)
Posted by: @eule
How to solve this?
You don't... Here, for your reading pleasure:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/buldge-when-print-reaches-solid-layers
https://help.prusa3d.com/article/the-benchy-hull-line_124745
Respondido : 13/12/2024 4:57 pm
Eule
 Eule
(@eule)
Uff, that's a lot of reading and as what I understood (haven't read everything), without a solution.
So printing a simple box seems to be quite challenging...
Thanks a lot for the support!!!
Respondido : 15/12/2024 9:27 am
Eule
 Eule
(@eule)
I now tried t oactivate "external perimeters first" setting and I guess it helped  a lot (not 100% sure, because I also increased the nozzle temperature by 10 °C.
But now I am getting ONLY at one edge of the box an ugly "pattern". Is this connected to this "external perimeters first" option?
Respondido : 19/12/2024 5:56 pm
Eule
 Eule
(@eule)
Respondido : 19/12/2024 6:36 pm
