Effel tower settings
So maybe I bit off more than I can chew. I am trying to print an eiffel tower model that is just as tall as my mk3 printer. I am having a fit with the small detail in that I am getting bad webbing. things I have tried. Reduce the temp to 200 which ultimately failed. My nozzle closed about 1/3 of the way through the print. I tried to increase the extraction distance and rate. I tried to reduce the flow and speed. Nothing i tried makes this issue any better. just wondering if someone has successfully printed this using PLA on the i3 printer.
thanks -- rr
Re: Effel tower settings
pictures and slicer settings would be helpful.
your best bet is to try and troubleshoot small details using something like this: https://www.thingiverse.com/thing:909901
a quicker and easier test: https://www.thingiverse.com/thing:22263
