detected object outside print volume
using slic3r pe 1.4.0
set for multi material
add 1st stl to plater
click setting and load part two
assign extruders
click ok
bottom of screen shows "detected object outside print volume"
What am i doing wrong please
Respondido : 01/09/2018 4:44 pm
Re: detected object outside print volume
Have you hit the "Arrange" button?
Respondido : 01/09/2018 4:56 pm
RE: detected object outside print volume
Nothing like raising a post from the dead, but you deserve a thank you! (From a newb who appreciates being able to quickly find the answer!)
Respondido : 28/10/2022 12:47 am
One thing that's not immeadiatly obvious is that the skirt is included in the "Outside Print Volume" calculation.
Respondido : 29/10/2022 3:20 pm
