Curling/Warping on ABS Print
Hi everybody,
I am experiencing a strange issue. It looks like warping/curling but it only occurs on one side of my spherical part.
The two parts were printed with the same export settings with a couple of days in between.
The first one (upper one) printed fine, the second one has these steps on only one side.
I am not sure if this issue falls into the category of curling or warping or is something different.
Setup:
- mk3s+
- ABS material
- 0.4 mm nozzle
- 0.1 mm layer height
- no support
- smooth sheet
- closed chamber
Can anyone help?
Make sure your fans are clean.
If that surface is critical, invert the part on the bed - you will need some support under the curves; use "Support on Build-Sheet" ... and why are you using 0.1 layers?
RE: Curling/Warping on ABS Print
Hi, thanks for your reply =)
It's the outer part of a ball joint, and I need the print as precise as possible, therefore I used 0.1mm layers.
I tried to print it like this because so far I got away without support material.
If I flip it and use supports, I might not get off the print entirely. But I'll give it a try.
Thanks for the tipps =)
