Cube with bumpy corners
Kevlar
(@kevlar)
Hello,
I downloaded and printed the visual cube to check for over extrusion. The top and bottom of the cube printed very nicely, but the corners are bumpy and not sure how to fix it? Any suggestions, please?
This topic was modified 6 years ago by Kevlar
Posted : 07/01/2020 1:20 am
Kevlar
(@kevlar)
RE: Cube with bumpy corners
I tried the Linear Advance( K value adjustment ) The best seems to be a value of 40 but it still looks the same. Below is the best I can do. It's two squares together, showing the uneven sides with a gap in-between. Tried different filament, PLA gray. I also tried the procedure to find the correct K value from the website:
https://mattshub.com/blog/2017/10/02/linear-advance
Posted : 08/01/2020 1:13 am
Josh
 Josh
(@josh-12)
I am having the exact same issue on my Prusa Mini.  Did you find a cause and/or solution?
Posted : 01/06/2020 2:11 pm
