Cooling fan nozzle abs
gatonini@zoominternet.net
(@gatoninizoominternet-net)
Hi
I'm trying to print this piece in abs it comes out looking like a piece of crap I'm using the slicr generic abs profile any tips or suggestions to make it better I believe the temp is 255 and the bed 100.
Thanks
Gary
Napsal : 24/01/2019 7:22 pm
RH_Dreambox
(@rh_dreambox)
Re: Cooling fan nozzle abs
Why not try my gcode attachment?
https://www.thingiverse.com/thing:3249344
Napsal : 25/01/2019 11:40 am
Martin_au
(@martin_au)
Have you got cooling on? A lot of people say don't use fan with ABS. A lot of people also don't know what they are talking about. 😀
Napsal : 26/01/2019 1:42 am
Peter M
(@peter-m)
Topic starter, if you do not give info, then nobody can help you.
Pictures and what is wrong?
What did you try?
if you do use a cooling fan on abs, then you get a not strong part, abs is normally no cooling fan.
Temps, try different settings.
Speed, slow down, a little bit, 75%.
Try different abs.
Napsal : 26/01/2019 12:06 pm
RHDreambox I printed the bmg extruder for the mk3 on thingiverse I then downloaded the nozzle package you have on thingiverse I printed out the nozzle gcode file you have there which fan bracket should I print for the bmg extruder I printed the bmg one and it doesn't work
Thanks
Gary
Napsal : 27/01/2019 6:28 pm
Martin_au
(@martin_au)
What did you try?
Try different abs.
Incorrect. You can get a very strong part with cooling. I do it all the time. Just make sure it's extruded hot enough to fully melt to the previous layer.
Napsal : 28/01/2019 7:19 am
RH_Dreambox
(@rh_dreambox)
Thanks
Gary
I have added a new file for BMG extruder with a nozzle support that should fit better.
The extruder files that I started from I found on Bondtech's website, but they were not the right ones.
After a tip I found the right extruder files on Github.
Napsal : 01/02/2019 2:29 pm
Peter M
(@peter-m)
Prusa has also the gcode for this, on there website.
Napsal : 04/02/2019 1:15 pm
