ColorFab Woodfill won't stick to print bed
michael.n24
(@michael-n24)
I cannot get Woodfill to stick to my print bed. Instead it just make a big ball of mess on the end of my nozzle. I printed with this once before and had no problems. The roll itself is several months old but has been kept in a desiccated zip lock bag. I am using a 0.6 mm nozzle. I have tried cleaning the bed with Isopropanol, acetone, and tried glue stick. Anyone have any ideas on what is going on?
Opublikowany : 17/01/2019 9:47 am
rob.l6
(@rob-l6)
Re: ColorFab Woodfill won't stick to print bed
Give your bed a good clean first, not just a wipe over. Then check your z height, and perhaps lower it a bit.
Opublikowany : 18/01/2019 3:21 am
michael.n24
(@michael-n24)
I found out what I was doing. I usually clean my bed using tissue paper. I just noticed that the last box I grabbed was tissue coated with 'soothing lotion' *derp*. I used different tissue without lotion, cleaned the bed well with acetone, and it works just fine now. I also lowered the z-height a bit.
Thanks for your help and replying Rob.
Opublikowany : 20/01/2019 2:47 am
