        Color change removal
Hello All
I downloaded a .stl from thingiverse. It is designed for a color change in the middle of the print. I just want to print it in 1 color. How do I remove the color change so it does not pause and wait for a color change in the middle of a print? Thanks
                            Postato : 13/10/2021 1:58 pm
                    Easy
You can remove the color change in Prusa Slicer. It will show a color change - and if you hover over the change point (on the layer slider bar) you can X out the color change. Then save your file (no longer an STL). Slice it. And Go.
                            Postato : 13/10/2021 2:54 pm
                    3 persone hanno apprezzato
