Circles not perfectly round
liang.phillip@hotmail.com
(@liang-philliphotmail-com)
Hi everyone,
I'm new to 3d prints. I tried to print a 100mm diameter plate and the edges aren't perfectly round as shown in the picture below.
Is it my 3d model that isn't correct or X, Y belt tension?
Thanks for the help!
Best Answer by adesir:
OK, the issue is at SolidWorks export to STL. You have to select fine resolution when exporting.
http://help.solidworks.com/2022/english/SolidWorks/sldworks/hidd_stl.htm
Veröffentlicht : 26/12/2021 6:36 pm
adesir
(@adesir)
RE: Circles not perfectly round
Welcome,
Almost all 3D printers are able to print near perfect circles. Either your model is not a circle, or the gcode sent to the printer is too simplified.
Mes modeles publics
Veröffentlicht : 26/12/2021 6:59 pm
The model is made from Solidworks and then exported to STL. I used the generated gcode from PrusaSlicer.
Any idea how to verify the gcode?
Thanks.
Veröffentlicht : 26/12/2021 7:31 pm
adesir
(@adesir)
Mes modeles publics
Veröffentlicht : 26/12/2021 8:13 pm
Thank you  Adesir, it solved the problem.
Veröffentlicht : 29/12/2021 5:27 am
