Card Lector
rodrigo.b
(@rodrigo-b)
Card Lector
Hello,i have to print a few of this cases. I am having trouble with the curved side. I am using the 0.2 preset from prusa slicer edition with raft and supports.
The issue is the short layer and the nozzle kind of leaves a mark.
Opublikowany : 04/05/2018 6:43 pm
Re: Card Lector
Hi Rodrigo. can you share the STL so we can see what you are having problems with?
you will have to zip the file before attaching it
Opublikowany : 04/05/2018 11:47 pm
rodrigo.b
(@rodrigo-b)
Re: Card Lector
Here it is. It s called SUP.
Also i have a second file called INF which i have the following issue, prints the sidesd super smooth and then its just awful in the middle and then you have a few nice layers and the end.
Both are printed with raft and support.
I was using 210c for PLA maybe its too much.
Opublikowany : 07/05/2018 9:43 am
rodrigo.b
(@rodrigo-b)
Re: Card Lector
This dots are killing me, i have minimum temp for this pla and maximum preset infill speed.
- over extruding? where do i change it?
- Z hop how can i reduce it?
- Z hop ?
- over extruding?
Opublikowany : 07/05/2018 10:24 pm
