Can´t resume the print after power outage
Richard_H
(@richard_h)
after two and a half hours of printing, I stopped it because I wanted to lube the axis. Somehow, maybe the power cable was badly connected I had a very brief power outage, but after the screen turned back on, the print resume option didn´t show up.  Is there any way I could resume it?
Thank you for your help.
Napsal : 19/01/2021 3:54 pm
Swiss_Cheese
(@swiss_cheese)
RE: Can´t resume the print after power outage
you mentioned you stopped the print, did you click the stop print option in the menu?
The Filament Whisperer
Napsal : 20/01/2021 4:11 am
Richard_H
(@richard_h)
@swiss_cheese
Yes, I did. BTW I may have used the wrong word, I didn't stop it I just paused it.
Napsal : 20/01/2021 7:42 am
@richard_h
I don’t think you can restart that print.
Napsal : 20/01/2021 10:42 am
Swiss_Cheese
(@swiss_cheese)
@richard_h
If you stopped the print, that's it you cant resume. if you paused the print you should be able to resume within a reasonable amount of time. If power panic kicks in, you should be given the option to resume once the power is restored. I've never had an occasion when I had a print paused and the power went out, but it sounds like it's not going to resume from that point, and you would need to start the print over.
Napsal : 20/01/2021 3:34 pm
Neah Chandel
(@neah-chandel)
I have had around 8 restarts in printing my model from scratch after every power  failure. The screen turns back with no option to resume and I have to clean the mat and start all over again. Please help!
Napsal : 17/01/2023 8:19 am
