Can't get supports to fill for large void on a prusaprinters.org print
TimeVex
(@timevex)
I'm trying to reslice this for PETG but I can't get it to fill support on the bottom. I've tried adding a large support enforcer block but no luck.
https://www.prusaprinters.org/prints/19926-spinning-bike-cell-phone-holder/files
Respondido : 26/01/2021 2:28 pm
RE: Can't get supports to fill for large void on a prusaprinters.org print
Most likely cause is you have Dont Support bridges enabled.  When that is turned on (which it is on default prusa profiles) then it doesnt matter what support enforcers you use as you are telling it NOT to put support under things it thinks it can bridge (even if it cant in reality).  That model is a prime candidate for that if you have it orientated as shown in the preview.  In fact your screen shot is showing the color for bridges on the preview.
Respondido : 26/01/2021 2:53 pm
TimeVex
(@timevex)
@neophyl
That was it! Thank you
Respondido : 26/01/2021 5:58 pm
