Can You Change the Infill Settings for Different Parts of a Model?
sfshook22
(@sfshook22)
I was wondering if you can change the infill settings for different parts of a model using PS 2?
Like having parts of the model solid while other parts with say a 15% infill.
Thank you,
Steve
Veröffentlicht : 02/07/2019 3:29 pm
RE: Can You Change the Infill Settings for Different Parts of a Model?
You can do it using modifiers. These shots were done with an older version of PrusaSlicer/Slic3r:
Veröffentlicht : 02/07/2019 3:38 pm
vintagepc
(@vintagepc)
Mitglied
^^ This definitely works, I use it on occasion to make the last few layers of infill denser in preparation for a cleaner top surface with fewer solid layers required.
Veröffentlicht : 02/07/2019 3:46 pm
Dave Avery
(@dave-avery)
yes, using a part modifier over the area you want to change
Veröffentlicht : 02/07/2019 4:06 pm
RAH1
 RAH1
(@rah1)
Posted by: bobstro
Bobstro,
Are you saving your settings for the objects in a project .3MF file?  Is that the way to go for getting repeatable results before slicing?
Thanks,
Robin
I am the inveterate tinkerer. I can tink up most anything.
Veröffentlicht : 02/07/2019 7:52 pm
Posted by: RAHRAH
[...] Are you saving your settings for the objects in a project .3MF file?  Is that the way to go for getting repeatable results before slicing?
I do that with complex projects, yes. I created a vertical test tower that used different parameters with modifiers at every 10mm for example. Definitely save as a project (3MF) if doing anything complex when you want to re-use the settings!
Veröffentlicht : 02/07/2019 8:10 pm
