Can I vary the infill at more than one "band" in Prusa Slicer?
Andrew
(@andrew-5)
Hi folks
In researching variable infill %'s I found that I can vary it between set layer heights. I just cannot see where/how I can do this multiple times in the same model. I have a medium sized model that will take 6h8m at 15% and only 3hr20m if the middle chunk is at 5%. But There are some bits that really could use some additional infill but they are part way up. I reckon 5% is too brutal but if I could switch between %'s at heights of my choosing I could have the best of both worlds. So my questions are;
a) - Can I?
b) - How?
Thanks in advance
Andrew
Best Answer by Neophyl:
See the knowledge base at https://help.prusa3d.com/en/article/modifiers_1767. You can either set multiple height range modifiers or you can use a normal parts modifier and set the infill that way in a specific area.
Veröffentlicht : 06/06/2020 2:16 pm
RE: Can I vary the infill at more than one "band" in Prusa Slicer?
Veröffentlicht : 06/06/2020 4:18 pm
Andrew
(@andrew-5)
@neophyl
Brilliant. Thanks. I will have a look at that.
Andrew
Veröffentlicht : 06/06/2020 4:27 pm
