Can I easily print in PETG, using a PLA gcode?
Jaxel
(@jaxel)
I have a generic PLA gcode. Prints great in PLA. It's pretty complicated though, and I did a lot in notepad++ splicing objects together to create this gcode.
For a reason, I have to print this in PETG now. Can I simply use this PLA gcode, set some offset temperatures in OctoPrint, slightly live adjust Z... and print in PETG? Or do I have to recreate the gcode, because other changes are needed?
Opublikowany : 22/12/2020 7:09 pm
RE: Can I easily print in PETG, using a PLA gcode?
Posted by: @jaxel
Normally, each filament type is assigned different parameters, such as temperature, speed, LA value, retract value, extrusion factor, and so on.
I also have PETG which gives ideal results at temperatures around 210 degrees C., but have never printed it with PLA settings. It is best to simply try it out on a small test part.
Opublikowany : 22/12/2020 7:34 pm
towlerg
(@towlerg)
Posted by: @jaxel
Perhaps you could slice for PLA and for PETG, determine the differences and apply them to your tweaked GCode file?
Opublikowany : 23/12/2020 11:22 am
