Can a 2D Illustrator file be given a Z value to create a 3D file?
I have a 6 layer Illustrator file (2D). 1st layer = 10mm; 2nd layer = 4mm; 3rd layer = 2mm; 4th layer = 2mm; 5th layer = 2mm; 6th layer 1mm.
I would like the whole 1st layer to be 10mm and each other layer it's thickness. Can I do this in Illustrator? Like adding a slice to increase the thickness of each layer until the desired thickness is reached?
Thanks for the info in advance!!
Dave
Opublikowany : 05/06/2020 6:28 pm
