bridges to nowhere - slicer generates print lines in air
hawai
(@hawai)
Hi everybody,
here's another weird one from me. The attached .mf3 produces some strange g-code. If somebody could kindly look at layers 10 and 11? Am I just seeing ghosts or is the slicer trying to close the holes with a bridge that ends in the air between the infill patterns?
Aesthetically I don't think it would be a problem as the blemish is well inside the object. But sagging filament may cause some problems in the next layers and generate a blob.
And, no, the objects can't be printed the other way round, because the side on the build plate will be the visible side and I want this to be looking nice.
So far my only idea would be to place an infill modifier around each hole and increase the density. That would be a lot of work and would increase the weight of the pieces unnecessarily.
Thansk in advance
Hansjoerg
Attachment removed
Veröffentlicht : 25/04/2021 1:08 am
Swiss_Cheese
(@swiss_cheese)
RE: bridges to nowhere - slicer generates print lines in air
it slices fine, but if its really bothering you for some reason set your bridging angle to 45 or 90, I think you  are in the same boat as a lot newbies, you are thinking that slicer is an exact representation of the physical world, it's not, no slicer is.
Just print it, the bridges will be fine.
Enjoy
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 25/04/2021 1:39 am
