Bridge Infill Tips Needed
BoCoKeith
(@bocokeith)
I am printing an object with low infill and a solid top on an MK3S+ using PLA.  For the first solid top layer above the infill PrisaSlic3r uses "bridge infill", but I am getting really bad results on that layer.  (See image below.)  I have run some bridging tests, and am getting acceptable results from them; and the bridging test gaps are certainly longer than the infill bridge.  I am using a 10% grid infill, and the grids are about 1cm apart.  Does anyone have any tips on getting a better bridge infill?
Postato : 30/09/2022 12:33 am
Utenti
RE: Bridge Infill Tips Needed
I have found that I need to flow the print speed down.
Here is another thread.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/bridge-infill-versus-support/
Postato : 30/09/2022 10:48 am
Are those gaps visible in the slicer preview?
Postato : 30/09/2022 10:51 am
