Bridge Infill Tips Needed
I am printing an object with low infill and a solid top on an MK3S+ using PLA. For the first solid top layer above the infill PrisaSlic3r uses "bridge infill", but I am getting really bad results on that layer. (See image below.) I have run some bridging tests, and am getting acceptable results from them; and the bridging test gaps are certainly longer than the infill bridge. I am using a 10% grid infill, and the grids are about 1cm apart. Does anyone have any tips on getting a better bridge infill?
RE: Bridge Infill Tips Needed
I have found that I need to flow the print speed down.
Here is another thread.
Are those gaps visible in the slicer preview?
