Bowed at Base, Overheating?
theycallmejohn
(@theycallmejohn)
Hello All,
Hoping for a little advice on this print. Haven't had issues in the past with my old printer when I printed fast in batches.
As you could see from the photo there is lot of deformation at the base. This is suppose to be a rectangular tube. These are printed in ABS with the PRUSA ABS FAST setting other than a Brim added and bed temperature a consistent 210. Additionally this is in an enclosure. I was thinking maybe cranking the fan on the hotend up to max?
Normally I would play around with the setting but I am kind of on a time crunch.
Napsal : 10/04/2020 3:12 pm
RH_Dreambox
(@rh_dreambox)
RE: Bowed at Base, Overheating?
I guess the bed temperature is 110°C, 210°C is completely crazy.
Napsal : 14/04/2020 1:03 pm
theycallmejohn
(@theycallmejohn)
@rhdreambox
Yes you are correct.
Napsal : 21/04/2020 6:22 pm
theycallmejohn
(@theycallmejohn)
Turning the nozzle fan on solved the problem. Don't know why Prusa's default setting have it off.
