Blobs of plastin in prints
andrew.h40
(@andrew-h40)
My printer gets about 1/2 way through a print then a large blob of plastic appears. i don't know where it comes from. Any ideas how to solve this issue?
From NZ. Ne to 3d printing
Postato : 05/05/2018 7:12 am
Re: Blobs of plastin in prints
Hi Andrew,
it's possible that your nozzle is loose this could allow plastic to leak out through the screw threads,
it's possible that you are over extruding & the nozzle is picking up plastic off the top layer
it.s possible that you had a failure earlier and didn't clean all of the waste off the nozzle/heat block
and it's possible that it's something else entirely!
Postato : 05/05/2018 10:19 am
andrew.h40
(@andrew-h40)
Have just watch it. i think the nozzle is loose
Postato : 05/05/2018 10:27 am
good that you have found the problem!
Joan
Postato : 05/05/2018 12:51 pm
