Blobs in Front corner
Utenti
Hello,
I have been printing for about two weeks, and now the last 4-5 prints have failed. The starting outline fails, and it ends in spaghetti and appears to have good bed adhesion after the outline.
Ther last three print have done something odd. The printer stops periodically and does to the front right corner and makes a bunch of clicks and extrudes a blob. How do I fix this?
Postato : 15/09/2018 4:03 pm
Utenti
Re: Blobs in Front corner
Ok, I switched from PETG to PLA, and now it is just curling around the nozzle. I am trying to fix it. I think it is a clog. Any tips?
Postato : 15/09/2018 9:31 pm
RH_Dreambox
(@rh_dreambox)
First of all, calibrate Z (in "Calibration / Calibrate Z" menu)
Clean the bed with detergent and warm water.
If it does not help, you'll need to recalibrate the nozzle Z level.
Postato : 16/09/2018 3:41 pm
Utenti
I got that fixed and now I am having a second problem. I loaded a PLA filament and it does to the far right corner periodically in the build and pushes a blob of filament out. Anybody know why it is going this?
Postato : 16/09/2018 9:22 pm
Utenti
This is really odd. I replaced the nozzle. It is still doing this behavior.
it starts printing and then goes up the front right corner and makes a much of clicking noises and purges a blob of filament. It does that once every trip around the print.
Any ideas why it is doing this?
Postato : 16/09/2018 10:29 pm
Utenti
I figured it out. It had to do with Simplify3D and the Gcode. I closed and reopened, and it works now.
Postato : 17/09/2018 4:49 am
