big problems with first layer
oter11
(@oter11)
hi,got my new mk3s+ for some weeks ago,built it,and printed 1kilo with filament with very good results,then i got a clicking sound from extruder,and it didnt extrude eny filament,so i did think it had a clog inside,did take the extruder apart,no clog,but the ptfe tube had got loose,so did put the clips on where it should be,and did the wizard and the calibration again,but i cant get the first layer good again,if i have the nozzle more away from the buildplate,the filament will not stick when it prints a corner,and it will stick to the nozzle,and i use primafix now.
i tried to fix this about 10 hours today,got it little better,but still far away what i had before the problem,so i really need som advise here.
this was before:
Posted : 23/07/2021 8:42 pm
Peter M
(@peter-m)
RE: 1
Some squares look like it is to low.
-First clean bed with dish soap, use a lot of hot water, do this a few times. Do this before you start printing, then the bed can dry wen heated on the printer, if you wash and do not print, the bed will get corrosion.
-Then you need a 100% first layer, and I think you are to low.
 Start a new first layer calibration, and start to high, then lower it for every square or parts of the square.
After rebuild or moving printer or a crash, do a z-calibration with nozzle and bed hot.
This post was modified 4 years ago 2 times by Peter M
Posted : 24/07/2021 6:37 pm
oter11
(@oter11)
i had a spare steel sheet,so i did try with that one,and its alot better now,some tweaking is still needed
Posted : 24/07/2021 7:00 pm
hawai
(@hawai)
Wash the sheet!
As said before, wash the sheet!
It's dirty, so wash the sheet!
Posted : 24/07/2021 10:21 pm
oter11
(@oter11)
is it possible to fix this?
-0.39600 -0.39150 -0.41450 -0.43450 -0.47900 -0.54000 -0.60200 -0.38450 -0.36350 -0.38550 -0.44200 -0.44100 -0.47550 -0.52100 -0.31300 -0.31250 -0.34000 -0.36975 -0.37300 -0.38650 -0.45050 -0.23250 -0.23500 -0.28550 -0.32400 -0.31863 -0.32850 -0.33850 -0.09850 -0.13450 -0.19300 -0.24338 -0.24900 -0.22800 -0.24850 0.04650 -0.04050 -0.14300 -0.20750 -0.20050 -0.17600 -0.16700 0.22300 0.07400 -0.06850 -0.18050 -0.15000 -0.09250 -0.05150
http://lokspace.eu/3d-printer-auto-bed-leveling-mesh-visualizer/
this is with lock nut,but i cant adjust enough,because the leveling probe fault under bed leveling
Posted : 25/07/2021 8:52 pm
Brad
 Brad
(@brad-2)
enter title here
Your last picture didn't look too bad but you should be able to improve those numbers slightly with your Nylock mod. Are you having problems with the Pinda?
Posted : 25/07/2021 10:18 pm
oter11
(@oter11)
yes,i cant adjust enough,becouse i get bed leveling failure,do i need to move the probe up?
Posted : 25/07/2021 10:29 pm
Ringarn67
(@ringarn67)
@oter11
What numbers did you have before Nyloc Mod, was it better or worse?
Does it just say "Bed leveling failure"?
Did you do XYZ calibration after Nyloc mod?
Btw, this page is, in my opinion, a much easier way to adjust your nyloc nuts based on G81 numbers.
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Posted : 25/07/2021 11:14 pm
Peter M
(@peter-m)
Check if your data is with or without , the software adjusting the data.
MK3 normally normally adjust the data to make a smooth bed. but you can disable this.
Posted : 26/07/2021 3:37 am
oter11
(@oter11)
numbers
Posted by: @ringarn67
@oter11
thanks,that was a better site,i have alot better numbers now.
0.09700 0.09500 0.07400 0.09850 0.08200 0.10700 0.08650 0.09250 0.11450 0.09250 0.06300 0.09400 0.10750 0.08250 0.11950 0.12100 0.11150 0.10088 0.11600 0.12650 0.08250 0.13550 0.15800 0.12750 0.11300 0.12962 0.13250 0.12700 0.16000 0.20650 0.17300 0.14863 0.15700 0.17250 0.14400 0.15350 0.20250 0.18950 0.15150 0.15850 0.15600 0.14000 0.12900 0.16900 0.18450 0.13300 0.15600 0.16450 0.15000
dont know if i need to get them eny better?
Posted : 26/07/2021 10:11 am
Ringarn67 liked
oter11
(@oter11)
Test
Printet a test print now,200x200mm,test Line got Loose in one corner,and got stucked to nozzle,but not bad result.
Posted : 26/07/2021 12:44 pm
Thumbs up!
Could that have been caused by a thumb print on the corner of the build plate?
Posted : 26/07/2021 3:06 pm
oter11
(@oter11)
re
Posted by: @joantabb
i dont know,i used ipa before the print,it did get loose in the corner,it was the singel test line before the print that got loose,so it got where the print was,i think the buildplate is on its lowest there,but i was happy with rest of the print,looked very good on underside too
Posted : 26/07/2021 3:13 pm
Ringarn67
(@ringarn67)
Dish Soap
@oter11
Ipa is good between prints on a CLEAN sheet, but to get a REALLY CLEAN sheet, (which is a must), use dish soap and lots of HOT water, dry it with clean paper towel, put it on the heated bed, 10 minutes on either side to dry out the last moisture.
This is a forum thread where there was a discussion around Nyloc mod, G80, G81, and some "why's" and "how's"
Posted : 26/07/2021 3:32 pm
re
I wash my build plate with Hot water and dish soap, rinse with hot water, and dry with Paper towel. , and don't use IPA.
I also have my bed at 70C for PLA
Posted : 26/07/2021 9:15 pm
Brad
 Brad
(@brad-2)
You could run the scan a couple more times and if the front right one consistently shows high on every scan then you could turn it CW a few degrees but stop at that point. Otherwise, you can end up chasing your tail!
Posted : 26/07/2021 9:41 pm
