Benchy printing problem with PETG
Jimbo70
(@jimbo70)
I am using Polylite PETG with my MK3S and a Hemera extruder. It is working well except for printing the white PETG filament from Polylite. The grey PETG is perfect.
Notice the tip of the stern corners, there seems to be some delamination with the uplifting. What setting do I need to adjust to make the stern and side walls better?
Napsal : 11/05/2021 6:02 pm
RE: Benchy printing problem with PETG
Posted by: @jimbo70
As a first step, I would reduce the extrusion factor. You have probably set it to 1. Go back 0.85 and compare the result.
wbr,
Karl
Napsal : 11/05/2021 6:12 pm
Jimbo70
(@jimbo70)
I changed the extrusion factor from 0.98 to 0.85. It does not seem better, maybe worse.  The right rear corner is worse.
Napsal : 11/05/2021 10:07 pm
Jimbo70
(@jimbo70)
For comparison, here is a Polylite PETG gray filament same machine same setting as the original pictures. Both are new rolls less than a week old and kept in an airtight box. I seem to have more trouble with white filament, gray black and silver seem to work the best.
I would like some settings that will work with white.
Napsal : 12/05/2021 12:06 am
@jimbo70
It probably does not seem to be due to the hardware. You can still try to print a temptower with the problematic filament and possibly reduce the feed rate a bit. The filament could also have deviations in the diameter. This also causes irregular extrusion.
Napsal : 12/05/2021 4:31 pm
Jimbo70
(@jimbo70)
I agree, but was hoping someone would find something I overlooked. I think the filament is out of specifications s and will just not work.
Napsal : 12/05/2021 10:54 pm
