Attempting Eiffel Tower print, how to improve?
https://www.thingiverse.com/thing:4048515
Used default prusaslicer 0.15mm quality profile
How can I make it so that the fine details aren't so messed up? Lower the print speed? Use a smaller height layer and/or smaller nozzle?
Thanks
Napsal : 27/06/2020 8:10 am
RE: Attempting Eiffel Tower print, how to improve?
Cut the model so you only have 1 corner of the model, and test, with different temps , speeds.
Do a temp tower test,
do a stringing test,
do a cube test, a cube which is open on top, so you can measure the thickness of wall an measure the whole cube, this is to adjust the extrusion multiplier of the printer.
And read your question, you give no info.
Napsal : 28/06/2020 11:29 am
