ASA printing problem
Cat6a
(@cat6a)
Hello,
I am struggling with printing ASA for quite some time now. I need to make these simple little signs (outdoor use) but somehow I am facing this constant wraping issue that I can not seem to solve. So here I am finally on this forum to ask you guys... Attached you'll find a small collection of the prints that I made so far but there are more.. a lot more. But I think you'll get a good impression also on the improvement I have made so far.
Progress so far: Image
What I did so far at the moment I started printing ASA:
Build an encloser (pretty sweet one)
Replaced a new brass nozzle
Pinda was not in the correct position (fixed)
Use glue for a good first layer (steel plate)
Clean the plate really good also with isopropyl alcohol
Got myself pretty comfortable getting the Z calibrated correctly
In the prusa slicer, I selected the ASA prusament filiment, using a brim and a under skirt draft shield. Also experimented between speed, detail ect..
Also tried different nozzle heat and bed temperature.
Belt x asis didn't seem right so tried to correct this, was quite an adventure on its own but I think I got it right now.... I think
Tried ironing, but that just made it a lot worse plus takes a lot more time.
So that's basically it, I just don't know what to do from this point out... I don't understand it's such a simple print.. at least I thought it would.
Publié : 30/08/2021 8:40 pm
Swiss_Cheese
(@swiss_cheese)
@cat6a
Can you post a Zipped up .3mf project file so that we can see the settings your using? as well you mentioned your using a steel sheet, what steel sheet are you using.
Regards
Swiss_Cheese
The Filament Whisperer
Publié : 30/08/2021 9:45 pm
Cat6a
(@cat6a)
Reply Swiss_Cheese
Yes, I am using this one: https://shop.prusa3d.com/en/accessories-mk3s-mk25s-mini/216-spring-steel-sheet-smooth-pei.html
Attached the project file.
Publié : 31/08/2021 5:16 am
Cat6a
(@cat6a)
Project file
Project file
Publié : 31/08/2021 5:19 am
Peter M
(@peter-m)
If you post a file , it needs to be zipped.
Clean bed, use dish soap, alcohol does not clean as good.
Z-layer needs to be 100% , sticking will get bad if you go to low or to high.
Search for asa if you need to use glue and what is the best steel plate to print on.
For warping, try lower bed temperature, more heat in the nozzle,  slower printing.
For warping let enclosure heat up for longer time before you print.
Enclosure maximum heat is 40 degrees, higher and extruder cooling will not work anymore.
Publié : 31/08/2021 5:58 am
2 personnes ont aimé
Cat6a
(@cat6a)
Reply Peter M
Thanks, Here I try again this time zip file.
Ok, I now use Windex and finish off with alcohol.
I think i got a good Z-layer did this over and over again.
According to prusa this is the plate you should be using.
Will try lower bed temperatur, slower printing I have tried.
I was aware.
I was aware
Publié : 31/08/2021 6:20 am
Cat6a
(@cat6a)
Project file.zip
.zip file project
Attachment removed
Publié : 31/08/2021 6:32 am
Peter M
(@peter-m)
RE: ASA printing problem
Windex releases the print(a print cannot damage the bed) , this is used for printing petg on pei sheet.
How to print:
-Clean bed: use dish soap, clean a few times, use a lot of hot water. In between you can use alcohol, but use a lot of alcohol.
After a few prints use dish soap again.
- First layer needs to be 100% good.
Both settings are for getting a good stick to the bed, and prevents the model sticking  to the nozzle, and preventing a big ball of filament sticking to the extruder and damaging the printer.
If you are not 100% if first layer is good, print a few cubes spread out over the bed, start printing, adjust first layer to high, and a few lines and adjust until it looks good. Check if there are no holes, lines sticking together, and if you are not to low. I am often to low, if I am confused I start at a to high position and start adjusting again.
Publié : 31/08/2021 6:52 am
1 personnes ont aimé
Swiss_Cheese
(@swiss_cheese)
@cat6a
As mentioned above clean your smooth PEI sheet with very hot water and dish washing liquid (with no additives) don't use IPA on the sheet accept in between prints and when you do use IPA use a Generous Amount.
When printing ASA or ABS on the smooth PEI sheet you need to add a release For ASA you will use (glue stick) not Windex, Windex is a proper release for PETG but will not do the job for ASA or ABS. ASA and ABS can stick so well to the smooth PEI sheet that it can damage it during release. The glue that came with your printer should work fine I also use Elmer's disappearing purple glue stick or layerneer bed weld. If you don't have the Kore's that came with the printer. I apply it in a # crisscross pattern (let first layer dry then apply seccond in opposite direction) don't go to heavy on the application.
I've looked at your .3mf project file and have a couple recommendations, you can take your infill % down to 20% 30 is a bit high for this application, also you mention your printing in an enclosure (A pretty sweet one) so the skirt is not going to do a lot for you, and can be removed.  The brim can be helpful, however you have "elephants foot compensation set to 0.2 and that is stopping the brim from making contact with the printed part, so I'm going to recommend turning it off by  "setting it to Zero" if you wish to use the brim.
I personally would not use a brim on this print, it has a lot of area for good contact. I would leave "Elephants foot compensation set to 0.2 and remove the brim and I would adjust the orientation of the print in the X axis.
I included and example .3mf with the suggestions I made added for you to consider.
361 Welkom_Swiss.Zip
Hope this helps, let us know how things go
Swiss_Cheese
Publié : 31/08/2021 3:09 pm
Cat6a
(@cat6a)
Good prints now!
@swiss_cheese
@peter-m
Perfect! I did everything according to your advice. The prints are now as they should be and how I wanted them to be. Now I only have 100 more to go...
Not sure what the issue was here but I think Cleaning the bed very well with soap, applying the glue the right way, and of course the slicing part must have been helpful. A lot of settings were changed, much to learn on my side...  And it prints soo much faster now!  I can't believe it, just under 2 hours. This is really helpful.
Really surprised by the effort you took to help a random guy like me on this forum. I really appreciate this.
Still, something is bothering me though. As I mentioned earlier I struggled a lot with the x-asis belt. And I still think this is not correct. Not sure if it is appropriate to start a conversation about this now on this topic but anyway..
When I do a belt test the x-axis is around 220 and 240 as for the y-axis it is almost exactly 275.
A slight adjustment for the x-axis was not sufficient (too loose) so I had to make a large adjustment by adjusting the belt holder on the extruder by just one theeth. At this point, the belt was not too loose and the tension now feels very similar to the y-axis. So I guess that's good but the numbers still don't make sense. Still the same so around 220 and 240 max.
Is this a problem or should I ignore this and just feel whether the tension is ok or not.
https://help.prusa3d.com/en/article/adjusting-belt-tension-mk3-s_112380 (This is what I did)
Publié : 03/09/2021 7:01 pm
Swiss_Cheese
(@swiss_cheese)
@cat6a
Your Welcome,
Take time and go over the .3mf file, there's a lot to learn in there.
If your happy with your print quality leave your printer alone.
Enjoy
Swiss_Cheese
Publié : 03/09/2021 11:53 pm
I don't know...I found the numbers shown close to useless. I much prefer the tension meter you can print from https://www.prusaprinters.org/prints/46639
Publié : 04/09/2021 10:52 am
