Anyone use: CARBONX PA6+CF GEN 3 CF Nylon
What's temp/bed settings are you using?
And nozzle size .4 or .6?
I can see filament coming out of the nozzle, then switching/jumping to the next spot to print, so it leaves behind a extra little 'string'
What I am printing is a intake brake duct. The inside is what I need smooth, not the outside. On my print, the outside looks smooth, inside leaves the extra string. ANY way to reverse it? in settings? Kind of like a reverse vase. A vase you want the outside smooth, inside doesn't matter. I need the opposite, inside smooth. There a setting for that? I can switch?
Those are intake brake ducts, I need the insides smooth.
This topic was modified 5 years temu by exm2572
Opublikowany : 06/07/2021 5:33 am
RE: Anyone use: CARBONX PA6+CF GEN 3 CF Nylon
Did you dry the filament before use?
Opublikowany : 06/07/2021 1:52 pm
Topic starter
answered:
do you have to dry newly opened filament? it is in a drying box now. Haven't try printing after drying.
Opublikowany : 06/07/2021 2:11 pm
@exm2572
Not all the time, but if I get stringing with PETG OR nylon, that is the first thing I think.
Opublikowany : 06/07/2021 2:17 pm
