Any experiences with Pela Blocks (lego compatible, parametric blocks)?
hartzell
(@hartzell)
Before I jump off into the deep end of the pool, I'm wondering if anyone has any experience printing Pela Blocks (homepage), (GitHub).
Tentatively planning to print them using Prusament PLA, but also have Prusament PETG.
g.
Posted : 30/10/2019 11:13 pm
RE: Any experiences with Pela Blocks (lego compatible, parametric blocks)?
Nice find! I can only share that I found PLA to be very stiff when printing (not) Lego blocks, making assembly difficult. Have not tried PETG, but read that ABS has just the right amount of flex and give for this application. Of course, if you're just using them for one-time builds, this is less of an issue. You might try using a bit looser fit which should be easy given the OpenSCAD source.
Posted : 31/10/2019 2:13 pm
rmm200
(@rmm200)
Well this is one I grabbed. Printing calibration block in PETG now.
Good find!
Posted : 31/10/2019 4:54 pm
Nikolai
(@nikolai)
I've printed other Lego compatible stuff and ABS was so far the best material for that. PLA is too stiff, PETG flex too much under certain conditions.
I'm wandering how long it will take until this site will go down. Lego is on rampage right now in regards to "compatibility".
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 31/10/2019 5:10 pm
RAH1
 RAH1
(@rah1)
@nikolai-r
Homepage down.  GitHub still up.
I am the inveterate tinkerer. I can tink up most anything.
Posted : 20/12/2019 3:43 am
Dejf
 Dejf
(@dejf)
Currently available here: https://awesomeopensource.com/project/paulirotta/PELA-blocks or here https://github.com/aospino/PELA-parametric-blocks/blob/master/PELA-block.scad
And wow, it does very good job, far more possibilities than what my thing does, but most of them I already planned 🙂
My opinion may not be right, but regret having so bad and right one too often.My models are things you can't see on any shelve. I create things that don't exist and that should be the…
Posted : 29/04/2021 8:57 pm
