An issue I've never seen before, 'truncated' X
Here's one from the Go Figure Department.
As part of my current project, I need a bracket that is almost as wide as the I3 build plate, or just slightly smaller than 250mm.
I swear I've done prints that use almost the entire X space before, and I've never seen anything like this.
The print centers fine and slices fine.
I did have to turn off the skirt to get it to slice without errors, but NBD, I've had to do that before.
When it printed, however, the first thing I noticed was the corners on the left (right in the photo below) side of the print looked square and not rounded.
Looking closer (you may have to expand the image to see these details) there's some visible artifact along with the truncation.
Out of curiosity, I started the print again and watched the outline of the first layer go down. There was no evidence at all of it hitting any kind of 'hard stop' or physical barrier at the left side of the print. It just appeared to draw the outline as expected, but with rounded corners on the right, and square corners on the left.
I then re-sliced with the model positioned catty-wumpus (for lack of a better term) on the build plate to give it a bit of breathing room.
I watched it print the (now allowed) skirt and the outline of the first layer, and it printed as expected, with round corners on the left and right side.
The print finished as expected, with round corners on all four sides, and no raggedy artifacts.
Has anyone else seen this? I am aware that I may be pushing things, but I could swear that I've done prints coming close to the full X width before and never noticed this.
This was with RepRappers ABS, all default (generic ABS) settings.
RE: An issue I've never seen before, 'truncated' X
Interesting. Do you have the 3MF or Gcode? Post it.
Here's the .gcode if you want to look at it or play with it.
I did inspect it, and it does appear to be ordering the extruder almost all the way to the left, and attempting to draw the rounded edges.
G1 X6.523 Y142.090 E7.42952 G1 X5.257 Y141.947 E0.03996 G1 X4.076 Y141.534 E0.03923 G1 X3.016 Y140.868 E0.03923 G1 X2.132 Y139.984 E0.03923 G1 X1.466 Y138.924 E0.03923 G1 X1.053 Y137.743 E0.03923 G1 X0.910 Y136.477 E0.03996 G1 X0.910 Y73.523 E1.97388 M73 Q0 S262 G1 X1.053 Y72.257 E0.03996 G1 X1.466 Y71.076 E0.03923 G1 X2.132 Y70.016 E0.03923 G1 X3.016 Y69.132 E0.03923 G1 X4.072 Y68.468 E0.03910 G1 X5.103 Y68.106 E0.03426 G1 X5.240 Y68.150 F10800.000
