Čeština
  • English
  • Čeština
  • Deutsch
  • Español
  • Français
  • Italiano
  • Polski
Přihlásit se
  • English forum
    • České fórum
    • Polskie forum
    • Forum Français
    • Forum Italiano
    • Foro Español
    • Deutsches Forum
  • Recent Posts
  • Announcements
Fóra
English forum
Original Prusa i3 MK3 & MK3S & MK3S+
How do I print this? (Printing help)
After a year of good pints one bad clog Fubar-ed me Help please.
    Poslední Příspěvek
martin.f28
 martin.f28
(@martin-f28)
Help if you can. I own a Prusa i3 MK3 It's been working splendidly for almost a year. Then disaster. It clogged and I mean really clogged. I had to replace the nylon insert tube because the one I had was stuck solid. Took the printer apart carefully and put it back together the same. When I started it back up it tried to calibrate and kept failing at step 2. No answers to be found. I tried printing and you can see it's not printing as nice and blobs are forming causing fails all with the same filament. Just as I was trying to finish a job. Any help or insight is appreciated. The one on the left is the one post nozzle clear . Same filament same exact print settings.
Left is post filament clog and clean point 2 won't calibrate. Left is post filament clog and clean point 2 won't calibrate. Left is post filament clog and clean point 2 won't calibrate. Filament clog print I am getting blobs that has my print failing
This topic was modified před 7 years by martin.f28
Log in to be able to post
Napsal : 21/08/2019 12:58 am
RE: After a year of good pints one bad clog Fubar-ed me Help please.
Step 2 of what?
Most common cause of a failure after working on the hot end is not following the E3D-V6 assembly instructions.  There are tricks that must be followed to the letter or you get messy prints and blobs falling off the heater block.
Did you use thermal grease on the heat break?
Did you preheat to 285c before unscrewing the nozzle?
Did you adequately set the nozzle depth before installing the heat break?
Did you preheat to 285c before torquing the nozzle to the heat break?
Napsal : 22/08/2019 3:23 am
ps: That stuttering sounds like a belt hopping or drive gear slipping on the shaft, a smaller chance of a seized bearing (add a few drops of oil on the rods both sides of the bearings and work the axes back and forth to get the oil inside the grease seals),  or a broken wire in the extruder cable bundle).  Life of the wires in the printer is limited. No one has ever said how many hours of use, but they do fail in time.  Try wiggling the cable harness as you are running the tests and see if you can force the stuttering.
Napsal : 22/08/2019 3:29 am
martin.f28
 martin.f28
(@martin-f28)
RE step to- second point in calibration process descrivbed below
If you read the error message in the calibration process on the Pruse screen you will notice it says proceeding to "Searching calibration point 2 of 4"  .... then "XYZ Calibration failed.  Bed calibration point not found"  - from observing the stepping motor and the belt and checking tension, the noise is from the stepping motor going to far because the calibration point 2 was not found, the point of failure.
Yes preheating screw before remove and install
On heat break install.  I was under the impression you set the heat break screw into the heat block then installed the heat block putting the nozzle on after the heat break was on the printer and pre heated to proper temperature.
I felt there was enough grease in the heat break put I will try adding some.
How do I tell if I "adequately set the nozzle depth ".  I took a picture and matched it visually, is  there a depth I can measure in micrometers.  what is considered adequate??
Instructions I followed are below.
https://wiki.e3d-online.com/E3D-v6_Assembly
Does that help clarify.  I was told to do a factory reset and reinstall the firmware, does that make sense.??
Napsal : 22/08/2019 12:57 pm
martin.f28
 martin.f28
(@martin-f28)
Last nights print
Napsal : 22/08/2019 12:58 pm
Texy
 Texy
(@texy)
Posting in the wrong forum. Your post may get better attention if posted here :
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/
Texy
Napsal : 22/08/2019 1:27 pm
RH_Dreambox
 RH_Dreambox
(@rh_dreambox)
@martin-f28
On the video I see that the nozzle is scratching on the paper which is wrong.
The nozzle must not touch the paper during calibration.
Lower Pinda 0.5 mm by loosening Pinda and rotating it clockwise half a turn.
If the nozzle is still scratching the paper, lower Pinda a little further.
Napsal : 22/08/2019 1:45 pm
The extruder jamming isn't anywhere near normal limits, so that is NOT what is happening.  Perhaps as RDH says, it is instead binding on the bed.  Hard to tell with the paper, but certainly possible.  If that is the case, adjusting the PINDA down a bit might help.
Napsal : 22/08/2019 5:24 pm
Texy
 Texy
(@texy)
Posted by: Texy
Texy
Now moved by the MOD team 😀
Napsal : 23/08/2019 11:55 am
Posted by: Texy
In the future they shall be referred to as the "Mod Squad".
Napsal : 23/08/2019 12:04 pm
  All forum topics
  Previous Topic
Next Topic
  Fórum Statistiky
598 Fóra
71.5 K Témata
502 K Příspěvky
12 Online
82.6 K Uživatelé
Poslední Příspěvek: INDX with cereal dryboxes Nový Uživatel: Tim Recent Posts Unread Posts Tags
Forum Icons: Forum contains no unread posts Forum contains unread posts
Topic Icons: Not Replied Replied Active Hot Sticky Unapproved Solved Private Closed
