ABS or PETG for fan shroud?
Walleye
(@walleye)
I need to print a new part cooling fan shroud for my Mk3 as the old one is a bit deformed by heat out at the tip and causing some layer issues. I have PETG on hand, but would ABS be better for a part that will get heat soaked? Is there a better choice?
Thanks!
Napsal : 17/07/2020 8:03 pm
Peter M
(@peter-m)
RE: ABS or PETG for fan shroud?
ABS is better and good enough, or a even higher temperature filament.
Petg is not good.
Napsal : 18/07/2020 5:41 am
jsw
 jsw
(@jsw)
I just ordered some of the PC blend for this.  It's arrived but I have not had the opportunity to try it yet.  I plan on printing both the stock one and that new version referred to in another thread before I take down the printer for this replacement and a few other minor tweaks.
Napsal : 18/07/2020 11:58 am
Walleye
(@walleye)
I've ordered some black ABS, should be here in a week. Until then PETG will have to do.
What is PC? Polycarbonate?
Thanks!
Napsal : 18/07/2020 2:43 pm
