Z offset needs adjusting after every print
Nishum
(@nishum)
Almost every single print i do, as i watch the first layer go down i can see it's printing too high so i have to lower the z. Usually between .04 and .08. I've calibrated XYZ and done 1st layer calibration. But it keeps happening. Almost every single print.
Postato : 20/03/2021 3:44 pm
hli
 hli
(@hli)
RE: Z offset needs adjusting after every print
Does the stored Z-offset change between prints?
One reason for needing to change Z-offset is that the PINDA probe is not mounted properly and changes position.
Postato : 20/03/2021 6:10 pm
This. Can’t think of any other reason why live z would have to be adjusted every single time
Postato : 20/03/2021 7:42 pm
