[Résolu] Z not working.
ernst.v
(@ernst-v)
Z not working.
Good Day all,
Our company bought a Prusa I3 MR3 a few weeks ago. It was working great, until the Z started acting up. At first it would stop working somewhere during a print, but now it doesn't function at all. dav
As you can see the machine is practically brand new. I have tried:
  • Restarting
  • Plugging everything out and in of the control board
  • Updating the firmware and rolling it back to the oldest firmware available
  • Running every test and calibration
  • Choosing all the options in the menu
  • Sending it command from my pc
But nothing makes the Z axis move.  Here is a couple of videos showing the problem
The Z motors do activate, the motors are locked to a position, but they do not rotate no matter what I do.
If any one knows what I can try next, I would appreciate any advice. Would this be seen as a factory fault and can I send it back and get a new control board sent to us?
Please let me know. Thank you
Kind Regards,
Ernst
Publié : 16/05/2019 9:02 am
Vojtěch
(@vojtech)
RE: Z not working.
  • Check that you can move Z by spinning the trapezoid threaded rods by hand (both simultaneously)
  • Check that the screwed-on dust protector caps aren't blocking the motors.
  • Check that the Z motor cables aren't pinched by the zip-ties against the frame. This can lead to a short circuit easily. Even if a single cable is shorted, both motors won't turn.
  • Remove the X assembly from the trapezoid nuts and see if it moves smoothly on the Z rods.
  • With the X assembly not connected to the threaded trapezoid rods, plug one Z motor into the X socket on the einsy, the other into the Y socket and vice versa (X and Y motors into Z). Then try moving the axes in Settings->Move axis. If Z motors move and X and Y are dead, then the Einsy board is toast. If it's still the Z motors that don't move, it's the motors or cabling.
Good luck!
Ce message a été modifié il y a 7 years 2 fois par Vojtěch
Publié : 16/05/2019 12:11 pm
ernst.v
(@ernst-v)
RE: Z not working.
Posted by: Vojtěch
Good luck!
Thank you. Ill give if try.
Publié : 16/05/2019 1:42 pm
ernst.v
(@ernst-v)
RE: Z not working.
I checked:
  • Z- motors move freely by hand
  • No brakes in the lines and no short circuits
  • Both Z-motors work if I plug them into X output
So Einsy board is probably at fault. Is there a Prusa support I can contact other that the forum to get the board swapped out/ repaired?  I did fill in the contact form on the main website about a week or more ago but got no reply.
Publié : 17/05/2019 1:06 pm
vintagepc
(@vintagepc)
Membre
RE: Z not working.
Use live chat in the store. Email support is not the fastest way to get a reply...
Publié : 17/05/2019 1:13 pm
ernst.v
(@ernst-v)
RE: Z not working.
Live chat sorted me out.  Thanks to everyone that tried to help!
Publié : 17/05/2019 1:42 pm
Vojtěch
(@vojtech)
RE: Z not working.
So did they offer to send a new board or was it something else?
Publié : 17/05/2019 1:49 pm
ernst.v
(@ernst-v)
RE: Z not working.
Posted by: Vojtěch
New board.
Publié : 20/05/2019 5:50 am
