Z height is lost
Gato
 Gato
(@gato)
Z height is lost
Every time I turn on the printer, wherever is the location of z is taken as zero. The real/previous value before I turned off the printer is lost. This is frustrating.
I just did this simple test: on the lcd I checked the z level and it was 25. I turned off the printer (pressed switch on psu). Waited 30 seconds or so and turned it back on. Checked z level on lcd and it was 0.
How do I fix this? Saw this with 3.2.0 and now on 3.2.1. Sounds like a software bug to me but what do I know. :geek:
Veröffentlicht : 20/05/2018 5:27 am
MrFlippant
(@mrflippant)
Re: Z height is lost
The problem is, that if things move when it's off, how will it know where it moved to? Rather than trying to make that a thing, they have it auto home before prints. It doesn't lose calibration through the power cycle, so it re-homes before every print and 9 point reading. You can make it auto home in the calibration menu, if you like to see it at home before even initiating a print process.
Veröffentlicht : 20/05/2018 6:47 am
Gato
 Gato
(@gato)
I might have not been clear. I'm not moving any axes while the printer is off. Filed this issue https://github.com/prusa3d/Prusa-Firmware/issues/755 that provides the steps to reproduce.
Veröffentlicht : 20/05/2018 7:49 am
PJR
 PJR
(@pjr)
Antient Member Moderator
This is not a firmware fault.
As mentioned above, how does the printer know whether nothing has moved after is has been turned off.
In fact, the Z axis will have moved; as soon as you remove power from the Z axis, the motors will move away from the micro-step position they are being held on. Ideally, every time you turn the printer on, you should calibrate Z.
And if Z is stored, then why not also store X, Y and E positions? Because, just line the Z axis, they can also move when power is removed.
The only way exact positions can be determined after a power on is to move to the end-stops.
Peter
Veröffentlicht : 20/05/2018 12:26 pm
Gato
 Gato
(@gato)
Thanks Peter for your answer. Since I created this post, I learned that the printer has a homing feature. This homing feature means that it is able to discover where is 0,0,0. There is no need to store information that could be outdated if I move things while printer is off and also shorten life of EEPROM.
Gaston
Veröffentlicht : 20/05/2018 8:35 pm
