Z axis won't go down
jnelson
(@jnelson)
One of my MK3S printers is having a problem where it seems to think that the z axis is always at the bottom. It's currently at the top and won't go down. I can manually move it down, but once it travels up again it won't go back down. When I try to move it down in Pronterface, it says "echo:endstops hit". When I try to auto home, it says "z leveling enforced" and attempts to move to the top but it's already there. This problem came up out of the blue, I haven't changed any firmware or settings recently. Any suggestions?
Opublikowany : 01/08/2022 2:19 pm
Check your electrical connections.  Pull and replace the plugs on the Einsy board.  Come back if this doesn't help.
Opublikowany : 01/08/2022 4:37 pm
