Z axis not moving
Alec Bishop
(@alec-bishop)
Utenti
Z axis not moving
MK3S 'Bear' was running fine until I had a TMC Overtemp error come up on the screen when the printer was sat idle, the next day the Z stopped moving when it was trying to probe the bed starting a print, but would still move fine in the 'Move Axis' menu.
Now though, I get no movement at all and just a light buzzing sound as if the motors are trying to move. I've lubed everything up and both motors turn easily all through the axis when power is turned off, I've reflashed the firmware and checked all the wiring and solder points for the driver on the board but everything looks fine.
Anything else I can do? Or is it looking likely the einsy board is kaput?
Thanks, Alec.
Postato : 05/12/2023 1:12 pm
