[Rozwiązany] Z Axis Calibration Fail
trevor.g5
(@trevor-g5)
If I lower the PINDA sensor, during the calibration process the Z axis lowers the extruder head and the calibration process stops and you get a calibration failed message.  Sensor about 1.5mm off paper.  Just noticed that the extruder is hard on the bed, guessing a bed sensor has triggered the failure.
If you lift the PINDA sensor as per 6.3.10.2, the extruder will start trying to calibrate, i noticed that the bed is being deflected.
The PINDA light is on, but how do you tell whether a signal is coming back from the PINDA to the motherboard.
Opublikowany : 26/11/2019 9:45 am
trevor.g5
(@trevor-g5)
RE: Z Axis Calibration Fail
just letting you know i had flashed firmware for Mk3S instead of Mk3. After reflashing with correct product firmware, z calibration was fixed.
cheers
Opublikowany : 26/11/2019 10:14 am
Olef
 Olef
(@olef)
FYI the PINDA light goes out when it senses the steel sheet. LED on = pinda off, LED off = PINDA on / triggered
Opublikowany : 26/11/2019 11:06 am
