[Résolu] Z-axis askew (malfunction during wizard calibration)
lkp
 lkp
(@lkp)
Membre
Hello,
At first, I had an issue where it said I had a loose pulley on the x-axis (then y-axis) even when the pulley tension was good (everything worked for 1 year before, did maintenance), I read that it might be a problem with the firmware, updated to 3.13.1, but now the z-axis malfunctions, only one side moves up 1cm and then it continues to calibrate. Later during the XYZ calibration, it gives the error "Calibration failed! Check the axes and run again." Does anyone have any advice on how to fix this?
Thanks
Publié : 24/09/2023 8:28 pm
lkp
 lkp
(@lkp)
Membre
RE: Z-axis askew (malfunction during wizard calibration)
Issue was with starting position of z-axis, aka when printer was off and axis were moved it assumed the starting position as position 0 (moved from there). Had to move z-axis almost to the top to fix it.
Publié : 26/09/2023 2:46 am
