Y Crash detected in the middle off a print while there is no crash -
help, all my prints are crashing without reason. I’m currently in the middle of a print and again the same issue. What can I do to safe the print.
I have an MK3 with MK3s firmware
Respondido : 30/05/2023 4:51 pm
RE: Y Crash detected in the middle off a print while there is no crash -
sometimes lack of lubrication is at fault, sometimes faulty bearings, Linear bearings or idler bearing, sometimes cable bundle behind heatbed drags on the frame, if you have Ubolts on the Linear bearings, they can be over tightened,
or the printer may be too near the wall, at the rear...
turning off crash detection may help...
Respondido : 30/05/2023 7:31 pm
