Y axis vibrations
Nospoon
(@nospoon)
Y axis vibrations
I' experiencing some loud vibrations on Y axis movement.
Here's a video showing the issue: https://www.dropbox.com/s/0c4v0ovr5ghl825/mk3_Y-axis_vibrations.mp4?dl=0
Any ideas on what could be causing this? I'm pretty sure it's not the bearings as they're running smooth with belt off.
Publié : 29/04/2018 7:29 pm
darKing
(@darking)
Re: Y axis vibrations
How does it sound when You move it by hand? Have you overtightend your U-Bolts?
Publié : 30/04/2018 12:04 am
Nospoon
(@nospoon)
This is how the carriage sounds on it's own with the belt taken off. The U-bolts are not overtightened, I even added a single wrap of electrical tape around the bearings for additional protection and vibration dampening.
https://www.dropbox.com/s/v2fjq0u4maunhsl/VID_20180430_214755.mp4?dl=0
Publié : 30/04/2018 9:52 pm
Nospoon
(@nospoon)
Ok, so I managed to get rid of the PSU vibrations (it was a mosfet radiator that was resonating), also readjusted all of the U-bolts.
It is way better now, however I still think the Y axis movement is too loud. The noise is clearly from the belt/motor movement, not sure why the Y axis motor is so loud while X axis is silent. I tried loosening the tension on the belt but that didn't change anything, so that's not it.
This is how it sounds in normal mode: https://www.dropbox.com/s/ubv8git45bmpeg1/VID_20180501_002222.mp4?dl=0
Publié : 01/05/2018 12:32 am
