Y-axis Travel Error
So far it has been about a week since I had a print fail. Printer detected the crash and kept printing. Y-axis no longer moves, belt tension seems to read whatever it wants. Tightened the belt, loosened it, took it off. Motor does not move at all when trying to calibrate, reflashed the firmware. Still nothing. Waited a week for new bearings as a precaution in case they may have gone bad, put the new bearings on today along with a new motor. Still the same issue. So far I have made it all of 2 prints in with this thing and it now seems to be a brick. Belt status on the Y-axis changes everytime I turn on the printer, regardless if the belt is even on it.
Firmware 3.8.1-2869
Belt status currently reads X-218, Y-79.
Publié : 25/03/2020 4:33 pm
