Y Axis Stuttering
austen.e2
(@austen-e2)
Y Axis Stuttering
My Y Axis keeps stuttering and I don't know why. I fiddled with the belt tension and it's calibrating fine in the xyz test. It seems to happen when the bed moves towards the front
Postato : 16/09/2018 5:53 am
austen.e2
(@austen-e2)
Y Axis Stuttering
[youtube] [/youtube]
I'm not sure what is causing this. The XYZ calibrates fine and I've fiddled with the belt tension but I cant seem to fix this issue. It's been having crash detection issues as well.
I just finished the build and it's been doing this since the begining
Postato : 16/09/2018 6:51 pm
austen.e2
(@austen-e2)
Re: Y Axis Stuttering
bump
Postato : 18/09/2018 5:25 am
Knickohr
(@knickohr)
Utenti Moderator
Why dou you multiple post same problem ?
https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/y-axis-stuttering-t24572.html#p107634
It will not go faster if you post multiple.
I merged both topics.
Thomas
Postato : 18/09/2018 11:40 am
austen.e2
(@austen-e2)
I created the first one in the incorrect sub. After noticing I created it in this sub and then bumped only this one. Thanks for deleting the other one.
Postato : 18/09/2018 10:41 pm
