Y axis Motor skipping or hardware problem?
Saman shafiee
(@saman-shafiee)
Hello Guys,
after upgrading MK3 to MK3S+ i get a specefic angle in each print regardless where i print my part on the platform. The skew comes always in the walls which are in Y direction. I have attached pictures below.
I tried to diassmble and reassmble, tighten the belt, changing bearings etc and nothing changed and the problem and error stayed the same without even changing itself.
Does anyone have an idea what might be wrong?
https://1drv.ms/u/s!AmUmC2Bt80xtpjj-0cxuukF1QOx9?e=syGZQ3
Publié : 25/08/2021 11:45 pm
Dan Rogers
(@dan-rogers)
Loosen the bearing holders on the X axis chassis
Looks like X is creeping - hard to tell in your pictures.   The bearings have too much pressure on them on the X carriage back plate.  Loosen those screws until they are almost falling out.
Publié : 29/08/2021 10:54 am
