Y-Axis: Loud resonance (help needed)
Dear all,
I've been struggling with a noisy Y-axis and hope someone here can help me.
Best Answer by Constantin:
I narrowed down the source and feel a bit embarassed how easy the fix has been.
So, anyone who's struggling with a noisy Y-axis (and the same issue like I had), check the Y-axis motor by pressing on it wth your finger. On my printer, the Y-axis motor had slight contact with the frame, causig quite loud vibrations/ rattling noises.
There is a Y-motor holder already uploaded with a 1 mm gap between motor and frame. You can find it here:
beefed up y motor holder with +1 mm
Best wishes,
Constantin
Not sure if I'm able to help much given that there's not too much information to go on here, maybe you can upload a video of it :).
some steps I would take are:
1. isolate, make double sure that the sound is the y-axis (maybe it's interplay between 2 different stepper motors? when the print head moves diagonally?)
2. if the sound is 'resonancy' then you can check it by grabbing firmly on the chassis + squeezing and twisting it with your hands to see if that gets rid of the sound, if it does, then there's hope.
3. get a dampener (foam or sponge) and put it under a plate that the printer sits on, I also made myself a concrete slab to further absorb vibrations. This makes a big difference!
4. you can try to loosen / tighten different combinations of screws on the chassis itself, it's what I've done, and it might feel like a bad idea to make parts of the printer looser, but I considered it worth it to get rid of some resonance on my part.
RE: Y-Axis: Loud resonance (help needed)
I was so surprised seeing your reply. I wanted to make this post, so I started typing it...then went to the print, trying to narrow down the noise with different prints I prepared for that issue and film it. Things didn't work as planned....I couldn't find a consistent pattern....so I thought I never sent this post :-D. I really don't know why I still send it - I never would make such an "empty & open question". So sorry - but at the same time so grateful to still see such a comprehend and friendly reply. I saved your answer and I am sure it'll help me to narrow things down.
But if an admin sees that, don't hesitate to delete my post. I didn't plan to post that 90% unfinished.
I would never end a question without any "thank you" note or proper friendly ending.
Thanks again & best wishes,
Constantin
Best wishes,
Constantin
