Y-Axis Completely Out of Whack
VTcivil99
(@vtcivil99)
My Y axis suddenly is completely out of whack.   It's position is not correct, it's crashing.   After attempting recalibration it will initially be right for a super brief time then act up to the point you can see the printer glitch, then the Y-axis coordinates are completely wrong (like zero becomes wherever it was when it glitched).   I've updated firmware, ran calibrations over and over and no luck.    Should I move on to Y-axis motor replacement?    X and Z seem completely fine.
Postato : 08/02/2024 8:16 pm
RE: Y-Axis Completely Out of Whack
Have you cleaned and lubricated the Smooth Rods and bearings?
Have you checked that the Idler roller is rotating freely and smoothly?
https://help.prusa3d.com/guide/maintenance-tips_23200
Postato : 08/02/2024 9:48 pm
VTcivil99
(@vtcivil99)
You were absolutely correct.  😀
I took off the Y-axis motor so i could move the table and it was very sticky in one direction and marginal in the other direction.   I cleaned the rails and used the prusa lubricant and it is butter smooth now.   I also cleaned the X and Z rails and lubricated as well.    Thank you for the input, I was thinking the stepper motor was bad but it was not.
Thank you,
Ryan
Postato : 22/03/2024 6:36 pm
