XYZ calibration fault
I have a problem with mi mk3, but i do not u what is nderstand has. The self diagnostics testand Auto-home is all right, but when start the XYZ calibrations the extruder does not go down when starting the Z calibration.
If anyone can help me, i realy appreciate it.
Thank you
Nastu Mishel
Opublikowany : 29/01/2019 7:17 pm
Re: XYZ calibration fault
its possible the z nuts are binding. loosen them up a turn or two, let it bonk z, and tighten them up before clicking continue.
Opublikowany : 31/01/2019 5:40 am
