X-crash with frame during print for no reason / Troubeshooting help needed
rpriegu
(@rpriegu)
Hello everyone,
I´m kind of new to 3D printing, so sorry if this a kind of basic consult... I readed in the forum a couple of similar cases but not exacly the same, so I decided to open a new topic...
I´have been printing for a couple of weeks with my MK3S (running Firm: 3.8.1-2869) without any problem (not layer shift at all, and good quality printing). But today during an expected 10hs print, after about 5 hours (print high around 5cm), the extruder lifted up couple of centimiters moved to the far right and crashed against the frame. The log showed 2 X crashes.
Recalibrated XYZ, did a print of a "test cube" and resulted fine, but when tried to print a different thing, this time, I got another crash but a high of around 5mm. Now I can see 4 X-crashes counted.
FYI, I had already printed this file without problem a couple of times already, checked the SD card and can be read without problem.
Checked the "Belt - Status" with the following values: X=253 & Y=285
Could you please, let me know what should I start checking to troubleshoot this issue?
Thanks in advance and regards
Ramiro
Respondido : 30/11/2019 9:49 pm
rmm200
(@rmm200)
RE: X-crash with frame during print for no reason / Troubeshooting help needed
Check for binding in the X and Y axis. This would be picked up as a crash - and you would lose orientation.
Respondido : 01/12/2019 6:59 am
rpriegu
(@rpriegu)
@robert-rmm200
I found that moving along the X axis was a little hard, so I loose the X carriage rear cover screws a little (1/4 turn) and greased on the rods.
Will make some new tests and report back.
Respondido : 01/12/2019 2:25 pm
rpriegu
(@rpriegu)
RE: X-crash with frame during print for no reason / Troubeshooting help needed [Solved]
I have already printed a couple of things after, everything looks good (no me X-axis crashes).
So realeasing the bolts and oiling the rods made the difference.
Thanks for your feedback @robert-rmm200
Respondido : 04/12/2019 2:19 pm
Mike F.
(@mike-f-2)
Trouble with layer shifts or crashes? After nearly 2 years of loving my MK3, it slowly got so it crashed for no reason and had numerous layer shifts in the X direction. Prusa forum helped. All I did was added some 3 in 1 oil (low viscosity lubricant) to the rods and then manually moved the extruder (via the settings menu) back and forth a number of times until the bearings were lubricated again. Fantastic prints followed. It’s like brand new again.
Keep the dust off your rods and keep your bearings lightly lubed.
Respondido : 06/12/2019 9:58 pm
rmm200
(@rmm200)
Oil on the rod is only a temporary fix until you can do a proper pack the bearings with grease.
Respondido : 07/12/2019 5:27 pm
